Radio won’t turn on
Lhoughton
2007 Yamaha at 230. Just bought it and can’t get radio to turn on. Checked switch,fuses unless there is one hiding?circuit breaker. Where should I go next? It’s a Sony drive s hu. Should I just replace it?
Lhoughton
The circuit was tripped and had to push it in with a dowel. Still not working so there is power to the switch
Acard7
SW Iowa
I’m thinking it must be a power wire to the radio if your radio switch has power to it. If you plan on replacing it it may fix it but who knows.
sunbyrned
Louisville, KY
I suspect you checked this but make sure your house battery is turned on.
sunbyrned
Louisville, KY
What is house battery? This is a single battery not dual
Gotcha! Mine has a switch to turn the batteries (house and engines) on. Maybe you don’t have or need that.
marcham
Comox, BC
AR195
Check that all wires are correctly connected to the battery. There may be 2 or 3 ground wires...
Is everything else working? Lights, horn?
Lhoughton
Everything else is working the horn is not but it has power and makes a noise that probably needs to be replaced. I did check fuse in head unit and it was fine. All the wire to battery look good too
