blacksapphirez
- Charleston, SC
- SX195
Thats really rusty to me. Those plugs were put in at 50 hours and only have 30 have on them?update at 80hrs... i've replaced them.
View attachment 207896View attachment 207897View attachment 207898View attachment 207899
sorry they are the same plugs that was shown in the original post. approx 70hrs on emThats really rusty to me. Those plugs were put in at 50 hours and only have 30 have on them?
Is it stored in a very damp environment?
On the water? Salt air?
thats actually pretty good theory... I do rinse the motor and do not run for extended period of time, (afraid of overheating) but I should run it a few times before storing so the moisture is "gone"The Mr1 motors had a lot of issues with plug #3 snapping due to being stuck. My theory was that the motor had a tendency to stop in a position that left the exhaust valve open moisture would get in and cause it to rust in place. The water boxes hold a decent amount of water and it could be evaporating and condensating in the cylinder. This is also why it’s important to fog the cylinders. I went to copart to view a boat that had the motor out of the boat and the motor was taken apart sitting in a box next to the boat, the cylinders had a massive amount of rust in them from rain water. For the first start up of the season the boat always pushes water out of the exhaust so there has to be a decent amount of water sitting about 2 ft from the cylinders.
usually every week/every other week... but this was over 2 seasons too so, i will try to "dry" out my water box from now onSo is this happening to your plugs after it sits stored for a while or does this happen when it’s being used regularly?
So a light bulb just came on in my head after reading these latest posts and I just realized that you started the other thread asking people about running in salt water and if they have as much rust as you do in your engine compartment.usually every week/every other week... but this was over 2 seasons too so, i will try to "dry" out my water box from now on
Even with revving the motor slightly to blow the water out It does not get it all out. Salt or fresh will not matter if its evaporation the salt is left behind. The combustion chamber is susceptible to corrosion due to the metals that are used and the corrosive gasses left over from normal operation. This motor was left outside for a month from a boat that was one year old I was astonished with how much rust had formedIMHO There is something else going on other than the water box not being blown out, but I could be wrong and it certainly won’t hurt to blip it a few times after putting it back on the trailer.
No way his plugs should look as rusty as they do if he is using the boat every one to two weeks.Even with revving the motor slightly to blow the water out It does not get it all out. Salt or fresh will not matter if its evaporation the salt is left behind. The combustion chamber is susceptible to corrosion due to the metals that are used and the corrosive gasses left over from normal operation. This motor was left outside for a month from a boat that was one year old I was astonished with how much rust had formed
the oil is absolutely clean. no leak inside.So a light bulb just came on in my head after reading these latest posts and I just realized that you started the other thread asking people about running in salt water and if they have as much rust as you do in your engine compartment.
If your spark plugs look like this and the engine compartment looks equally rusty, I think I have some bad news for you. You either have a bad head gasket or a cracked block or cracked head.
You likely have salt water spraying into cylinders when running and also spraying out into the engine compartment. You said the boat was never submerged since you bought it with 10 hours one it so this explains why you have rust all over the place in the engine compartment and also see your spark plugs rusting. Salt water spraying into the cylinders and out of the engine explain both of your problems.
How does your oil look? Does it ever get grey or milky? Does the oil level rise at all?
If you have salt water spraying into cylinders, I would be worried about the bottom end of that motor as well as the valve train.
