2kwik4u
- Buffalo, NY
I've been reading for a few days now on the factory bilge pump in my boat. I'm somewhat overwhelmed with anecdotal evidence at this point, and have talked myself in circles.
Best I can tell the '17 AR190 has the "cycle every 3 min" style pump, and it doesn't operate without the battery switch on, and the dash switch on. This holds true in practice as best I can tell. Bilge doesn't run without the switch on that I've seen, however I rarely have the boat in the water without the switch on, so it's not really "confirmed" at this point in practice.
We're heading on vacation on Saturday morning. By Saturday evening the boat will be in the water at a private dock on the lake. I have intentions of leaving the boat in the water until the following Friday night (or Saturday morning). 6 nights on the water. If they boat is on the water, I want the bilge on. While sinking at the dock would be relatively shallow water, I would prefer to avoid that. I've done as best I can to remove as many leak points into the boat (cupholders plugged, rear tray re-sealed, couple of thru-hulls resealed, plug O-rings lubricated), and the boat will be covered when not in use. I suspect even a heavy rain will only allow a small amount of water in the boat at this point, however that is also not confirmed in practice yet.
I have also recently realized I don't have enough extension cords to get from the house to the dock. So plugging in at night (with a battery tender) isn't really an option, without purchasing more cords. I do have a spare deep cycle battery sitting around though. We're taking 101,285 things with us on vacation, and I would prefer to leave the spare battery at home if I don't need it. We'll probably be using the boat every day at some level. Some days we will be doing nothing but boating, other days it might just be an evening cruise.
My concern is draining the battery while at the dock. Worst case is thunderstorm, dead battery, no bilge pump, sunk boat. Second worse case is go to take everyone out the next day and dead battery exists. How much power can I expect the bilge, and idle stereo to draw under this usage?
My initial thought was to take the second deep cycle, and move the connections over to it every night and let the bilge drain that battery overnight, then move back to the permanently installed battery during the day. Taking the deep cycle up to the house each day to be topped off by the tender. This feels like more work than I really want to do while on vacation.
Would love it if this was a "set it and forget it" type situation, but I'm skeptical. This boat tends to "leak" a bit more than any boat I've had in the past. My previous boats were bone dry after days on the water, and the bilge pumps were always float switched, not pulsing. I considered replacing the bilge for this trip, but there are already mounting costs, and this bilge works, just not 100% the way I would like.
Can my stock AR190 battery (I think it's a group 24 Interstate, I'll verify tonight) handle the load for 6 nights with some assumption of at least a small charge being put back into it every day? Should I take the spare battery and tender, and have that setup as a "backup" in case I need it? Seems some say a few days on the water is no big deal, others have reported the cycling bilge pump draining a battery in as little as 3 days.
