dan144k
- Palatine, IL
We were riding in after some sunrise wakeboarding and surfing, cruising athe about 25mph for breakfast restaurant. Heard aweful, turned off engines. Checked clean out plugs, they ok. Felt clean outs for debris, and something was wrong. Boated in the test of the way on one engine.
Pulled the boat and found a snapped impeller blade. Had no warning or performance change prior to breakage.
Impeller stuck on shaft, snapped the teeth of both holding tools. Cut it off with a cordless grinder and 4 cutting wheels.
Did not have spare port impeller so we installed a starboard impeller and boat runs good enough.
Broke at 9 and back boating at 2pm.
Edit. Impellers 3 years old and we're repitched 2 years ago, so Zero warranty available.
Also only thing I have changed recently is the lucky 13 cones, and doubt that would cause the problem.
