Surf setup 2015 242LS
I just ordered parts for this experiment/mod. I'll update here once I get things put together. Here's a rough sketch of what my flap would look like...kinda going w @Scuba_ref idea.
I'll be darned. Can't wait to hear how those work!
I think you will need that center part to be longer but bet it'll end up being @Scuba_ref - 1 : @swatski - 0. LOL.
We need to determine what works, and let's go surfing behind our Yammies!
Im going with a different theory...but won't know til i get all the parts in and mounted for the test. Hoping will be all done within a week, and that this nice tx weather we've been having continues!
I have been watching this thread closely and two questions always come to mind.
1. That flap thing must be ridiculously heavy making it very difficult to manage on the water and just not practical.
2. Why not just make your own wake wedge. It's already been proven to work and you obviously have to know how and the tools to build one?
I built my own a couple of years ago. Mines slightly different than the original but works great.
RE: 1. My version 2.0 is a bit easier, the first one was crazy heavy. Yes that is an issue, the way I see it, it needs to be either a "set-it-and-forget-it" or "easy to mount" kind of a deal. Easy to mount - it is not. Storage is another issue albeit mine does fit in the ski locker.
RE: 2. Several reasons. I wouldn't mind supporting the guys, the issue for me is changing sides. That is a big one. I would also want it automated which further complicates things. The flap, silly as it is, may actually do. I think it needs to be angled, the shape is TBD I guess, but I actually think I'm pretty close.
Ultimately, this whole field is moving away from listed to tab/Surfgate/TAPS/GSA driven wake making, lets see if we can keep up! It is amazing what has happen in the last two years. But of course jet boats pose particular challenge.
We know that surfgate does not work on jet boats, however the GSA/TAPS should. Of the two, I decided the GSA (or WaveMaker)-like system is a better bet because I can combine a function of tabs for cruising and surfing. Just need to finish building my tab adapters for testing the latter.
EDIT: And of course, there is the awesome ASP (aerial surf platform) for the Chaps. But I think it does better in providing extra real estate for the swim platform than in surf augmentation.
I admire your tenacity and I hope you manage to succeed in making a surfable wave without haveing to list the boat. However, the wakewedge works well and switching from one side to the other takes less than a minute. (If you have two) Also with the wedge there is very little if any adjusting. I basically install my wedge, and fill up the boat with ballast and go surfing. Rarely do I make adjustments to the wedge itself and if I do is a matter of one or two turns on the turnbuckel.
Oh the boat will be listed, I'm just hoping I can make my custom tabs (w/mods) do that.
My family has never surfed on our own boat (we have done it with friends), I am pretty committed to make it happen.
The way I think about it, it boils down to few simple issues:
1. Haul enough ballast
That's no problem per se but the power may become limiting as the pumps need to be able to move the boat. I have the L13 cones in place which gives me some room for tuning - venturi and impeller tweaks, may also consider ECU reflash.
2. List the boat
There are limited options here: a. ballast alone, b. surfgate, or c. tabs system. The GSA-like tab system for attitude adjustment and delayed convergence is the way to go, I think.
3. Alleviate jet wash
Flap is the simple solution I never thought would have worked -- until @COtoFLsurf showed us.
I can't blame you for making your own wedge device, at $800 plus shipping a piece it is worth a bit of effort for sure.
Especially when you do the conversion from American to Canadian dollars.
Chilly,
Care to post a pic of your gate? I am in need of projects. Cam.
@KXCam22 Here is a couple of pictures of mine. If I was to build it again, I think i would just make it one piece as no one ever uses the swim ladder to board the boat because it's so easy to get back on the boat when its listed. I used 1/2" marine board for the wedge and 1" marine board for the crossbar and the ladder bracket. Everything is held together with a heavy gauge aluminium piano hing and 1/4' stainless steel bolts. I was a little concerned with it being all plastic at first but after two years I've had no issues so far.
The results.
@RightStuff No pictures of it mounted on the boat. The boat is all wrapped up in winter storage. Probable another 6-8 weeks before I get the boat back.
Ok I looked trough some pictures and if you zoom into the swim ladder you can see the mounting bracket for the wedge.
View attachment 51838 View attachment 51839 View attachment 51840
The results.
View attachment 51841 View attachment 51842
Wow, that is great looking wave.
Is your goofy wake looking better than regular or is it just in pictures?
@Chillypilot You have an awesome wave/wake, how many pounds of ballast are you using?
I think it may just be the angle of the photo. Here is another shot from the regular side.
Question for you guys. We are trying to deflect the jet was, right? Last year I tried attaching one of my boat fenders between the tie down and the ladder, problem is that my boat fender has a diameter of no more than 6 or 8 inches leaving it far away from the jet wash. I'm thinking of trying to do that same thing with a larger boat fender such as:
https://www.amazon.com/dp/B01N0S542J/ref=olp_product_details?_encoding=UTF8&me=
What do you think?
