- Royal, AR
- SX
Wouldn't you have to have Geothermal HVAC system in order to use a water heater like that Bruce?
No, GE calls it a GeoSpring but it is simply a small heat pump on top of a hot water heater tank. It has conventional heating elements inside and can act as a normal hot water heater when greater volume is needed. When the heat pump is running it cools and dehumidifies the air as a byproduct of heating the water. There are many similar units on the market today. These State Premier® Hybrid Electric Heat Pumps came out soon after I bought the GeoSpring and would likely have been my choice.
