Welcome to Jetboaters.net!
Am I missing something? I lube them, spray them down with silicone, yet they still end up stuck in a year or two. Stopping at tractor supply tonight to grab a new one.
I pulled my stuck jack today and headed to tractor supply. They had an almost exact match for my 2015. I had to use the old pin though. The new jack had a larger diameter pin but also had a proper sized mount for the smaller pin. The new jack was $30.
I've had four Fulton f2 trailer jacks now, two of them (I got used) both died (stripped the gears on one and tore the wheel off of the other). I can see the other one is headed to the graveyard soon (the cap is no long the same shape as the that of the opening it is meant to cover).
I didn't know about the life time warranty. I was going to simply take the parts I needed from the dead units to keep the others in working order. I swear by the Fulton f2 winches but once my last f2 trailer jack dies I will never buy another. The cheap ugly stock one worked just fine , I should have never fixed / replaced what was not broken.
I'm embarrassed to say I got mine from the local Harbor Freight Tools. When my OEM jack broke I needed a replacement fast and didn't have time to research the issue. I picked up this one for $29 expecting it to get me through the rest of the season at which time I would buy a good one. http://www.harborfreight.com/1500-lb-capacity-dual-wheel-swing-back-boat-trailer-jack-69779.html This has a 1500 pound capacity and has dual wheels making it easy to roll an empty trailer. I have actually had people at the ramp ask where I got it. Oddly enough, it has performed great for the last 3 seasons and I will be starting my 4th season with it shortly. All I do to maintain it is spray it with T-9 at the beginning of each season as I boat exclusively in salt water. There is no rust on this jack and If/when it fails I will buy another.
