HangOutdoors
- Royal Oak, MI
Slide the boat back a couple few more inches?
This topic has been beaten to death, and videos like that have been posted plenty. Shorlandr, the manufacturer of this trailer themselves clearly state that for their tandem axle trailers to set to 5 to 7%.I would keep the tongue weight to 10 - 12%. A little extra tongue weight will not hurt anything, but not enough tongue weight can cause a catastrophic accident. Look around the internet at hitch/tow equipment manufacturers - 10% is usually the goal.
This video shows the issue:
I would go with the 10% for the reasons I previously stated - a little extra tongue weight = no problem, too little tongue weight could cause a catastrophic accident with sway. With my boat the recommended tongue weight (@6%) is just over 200 lbs.; if I use 10% it is a little over 300 lbs. I would rather have an added margin to account for different loading of the boat (maybe it is not quite as snug), differing loads (fuel level in the boat, gear in or not in the boat) and etc. There is no sway control in the standard set up. For that reason, I would rather have an extra 100 lbs of margin; it would not take too many changes in the previously listed variables to change your tongue weight to something that is below a safe level.This topic has been beaten to death, and videos like that have been posted plenty. Shorlandr, the manufacturer of this trailer themselves clearly state that for their tandem axle trailers to set to 5 to 7%.
Why would you go beyond the recommendation of the manufacturer when its stated in black and white. And to boot the trailer tows much better when set right.
Second on the weigh safe hitch. Been using for years on 20+ ft enclosed snow trailer and boat. No issues. Checking tongue weight takes 1 min max.
Ok i have set it to roughly 7-8%. It tows like a whole new trailer. Took it on freeway and everything.
Appreciate it
550lbs circa
