TOGA
- Chattanooga, TN
- SX
Will try to provide as much detail as I can as this is an item I have no experience with and need guidance.
2006 Yamaha 230 ho
Started getting the flashing code for incorrect voltage. Understand this can be caused by a faulty voyage regulator.
I have a blue sea dual battery set up. I only receive the error when I am running on both batteries. When I switch to one battery, the error goes away.
Yesterday on the water I was running in one battery and the stereo started to cut out because of insufficient power to amps. I switched over to 2 batteries hot thinking I could drain both. Well, I did. Had to jump myself off with one the little jumper packs that are so popular now.
Put batteries on charger last night. Within 1 hour on water today the stereo starts cutting out. I was not receiving and error for voltage today.
Status light on blue sea: when on single battery, led flashes stating voltage lockout. No warning when switched to both batteries.
Please treat me like a freshman on this subject.
If the voltage regulators go bad, does that restrict the batteries from charging while running, or don't have a stator problem too?
Could it be a bad battery. One is the one that was in the bit when I bought the boat 4 years ago. It is hooked up as battery 1. Second battery was added last year.
Wondering why battery is draining without voltage error on indicator lights.
I don't want to get educated in replacing voltage regulators before Labor Day weekend if I don't have to.
All guidance appreciated.
2006 Yamaha 230 ho
