- Acworth, G.A.
So I was cleaning the boat over the weekend, and found some NOT so nice things.
Mind you, she only has 6.4 hours and been out 4 times.
I found a crack in the gel coat on top of the gunwhales under the windshield on the helm side. It looks to me like the screw for that section may not have been pre-drilled possibly. The Crack runs under and is visible on both sides of the windshield.
![20140624_173315.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/7/7572-50212953af670d2212c891b38c228e8c.jpg)
Then I found the transom table mount was burning the rear mat (like otherside on here have noted) I taped over it for now.
![20140624_172752.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/7/7575-b1d4e8f83d6bfff5c4a60ca4b2b050d4.jpg)
![20140624_172727.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/7/7574-cfc95f2328a3b19b5fee6e7a2bdad866.jpg)
Then I found some irregularities in the upholstery which have been there since day one. While I figured I would be able to wipe them clean when I got around to it, it turns out that was not the case. . . . not sure exactly what the deal is there but it didn't wipe up with ANYTHING I tried. Including simple green, Wesley's bleach white, standard boat soap, etc. . . ( all of which I rinsed thoroughly with fresh, clean water after each attempt)
![20140624_173352.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/7/7576-8abd32fc2a2529e7bc915220e0a3d5db.jpg)
![20140624_173402.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/7/7577-afecaca93504bf3824c06b8fd71f5c46.jpg)
Then to top it all off I noticed that the carpeted panel on the port side where the battery switch is mounted was not secured. The panel is just hanging there held in place only by the carpet and the glue that is binding the carpet to it. Surely this can't be meant to be loose?
Are these items covered under warranty?
Edited for spelling
![20140624_173252.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/7/7573-e0edc4332c6e75b2dacb7e0b639ad9ec.jpg)
Edited for spelling
