mabr0503
- Yuma AZ
- Other
- Other
- Other
So I am a new jet boat owner and completely unfamiliar with them. Is there a way to drain water that is in the engine compartment other than the pump switch? With regular boats there was always a plug that you could pull on the back by the propeller.
Apparently there was either water from the storm or water from the lake trip. Either way I park in on a slight slope so it all pooled into the floor compartment. I wet vac’d it out but I also pulled it off the slope and raised the bow to see if I could get the water to go backwards but it all is just staying.
