Wayloncle
- 73703 Enid, OK
I have a 2017 Chevy 2500 with integrated brake controller, my boat trailer is a Platinum with electric/hydraulic brakes.
I have noticed the lights aren’t working all the time, my 7way plug has a crack in it so I figured I’d just put a new one on. The ground wire was pulled out of the terminal inside the plug, so that was that problem. Still put the new plug on, all lights work fine, reached in the window and pulled the brake controller lever and heard the hydro pump run. Cool.
I got in the truck and pressed the pedal and didn’t hear the pump. So I checked and brake lights work with the pedal, just the brakes aren’t working with the pedal.
im assuming there are some sensors between the pedal/master cylinder and the brake controller that is not working?
A quick interweb search didn’t find anything like this for a Chevy with integrated controller.
anyone had this problem or have an idea?
