What do you guys think of this gauge? Seems to do everything...
I like it especially if you are cramped for space
I have this right now, I just mounted it in my OEM speedo location. Just not 100% on the integration to the oem wiring. There is a "Gauge data" wire coming off the back of it, not sure what that does.
All I really need is gps speed/tach/fuel/voltage. Those work?
As mentioned elsewhere, it's from the factory speed sensor - just ignore it and connect +/- wires for the GPS speedo and you should be good to go.
Unlikely you will get RPMs on this thing from a Yamaha...I don't see any info on what it does use (NEMA 2000?). So it would work as a GPS speedo....since it says it comes with the GPS puck.... for the rest....who knows (but Yamahas are a proprietary system...so I can nearly guarantee it won't work for RPMs on a Yamaha out of the box).
To @stpetesearayderf16 I agree...Yamaha doesn't use standard NMEA 2k for their systems so you'll probably just get speedo functions.
