FSH 210 Sport
- Tranquility Base
- FSH Sport
Ok so used that calculator you posted for altitude and it looks like currently the lake I go to with all the current weather inputs shows a altitude of almost 7600 ft elevation. Conditions are almost identical to what they were Saturday. So with that being said should I have Glen repitch it again for around 7500ft ?
Did you have Glen pitch them for 4200’ as mentioned in an earlier post?
You need to contact Glen and tell him what rpm’s you are getting now and he will adjust. I would tell him that the density altitude is 7600’ of elevation and see what he says. In my experience he was very willing to help me out and worked with me to get the best out of my set up.
It also depends on whether or not this will be where you use the boat exclusively. It that is true then go for the 7500’ of elevation.
If it was me, and the fact I go to lower elevations, down to 1500, I think I would split the difference.. to maybe around 6000-6500‘ and see what that gets you.
I meant to put this in my last post. I spoke of the cavitation thing. With my OEM impellers I could punch off from idle with no cavitation and it would leave hard, but would then pretty quickly start to flatten out acceleration wise. With the impellers I have now, if just punch off from idle both pumps will cavitate then recover. However, if I walk the throttles up pretty quickly there is no cavitation, but the boat does not launch / leave as hard as it did with the OEM impellers, BUT BUT BUT, as the boat accelerates there is what I would call a mid range hook where you can feel the boat really start accelerating hard where it would be falling on its face with the OEM impellers. It’s like having 3:33 end gears in a truck, in first gear it will pull very hard, but as you put more load on the truck the performance starts dropping off and the engine will not rev up into the power band so to speak. Then you 3:55 or 3:73 end gears in it, if you punch off in first gear you will spin the tires at first, but once it gets going and it hooks up it will start to accelerate hard where with the 3:33 end gears it was falling on its face.
Everything is a trade off. But right now, you need to trade off pitch to get your engine up to rated rpms where the engine is making peak hp and is flowing the most air.
