FSH 210 Sport
- Tranquility Base
- FSH Sport
Thanks!
Your density altitude was 2878’. I had to make some assumptions since I didn’t know the other parameters of altimeter and dew point. I don’t have a good feel for a SC engine and how it would be affected by that 2900’ elevation but I’m sure there is some affect, maybe 5% or 25 hp loss.
I don’t know the conditions when you tested the oem impellers.
I’m assuming you already have the 12/18’s, if not you could have Dave at leading edge take some pitch out of the ones you have, much less $$$ to do it that way.
If it was me, I’d try the 12/18’s or repitched first and see what rpms and performance you get out of those. I’m sure you will gain rpms, it will be interesting to see if the 12/18’s get you back up to the oem impeller rpms range / speed or closer to the rated max rpm of 8000 and should get you back up to the oem top speed?
If I remember correctly, the tuner will only give about 5 hp at the stock rev limit of 8000 rpm, raising the rev limit to 8500 is where the 25 hp gain would be seen, but that requires a lower pitch impeller to get that many rpm.
