Brian_NY
- 252SD
I have been having an issue with this boat since it was new. Out of the gate I noticed that the starboard reverse gate is slightly higher up than the port gate. I asked the dealer several times to make the adjustments to get them in spec. I have been told each time that there is nothing they can do because there is no more threads on the linkage to lower the gate any more. My boat always wants to do a slow circle and it does make docking a little bit more difficult. Fixing the linkage issue would also allow me to lower my buckets a hair to help offset the slow creep I get while in neutral. I can't take it anymore and have thought about looking for a prop boat instead.
Does anyone know if there is some way to fix this. I am my wits end.
Thank you kindly!
Thank you kindly!
