I as well would like to see what the Bimini looks like. Any photos out there?Would like to see Bimini Top up
That screen being downsized in that frame is a joke, just makes you feel kinda like you got the watered down versionMy thoughts so far.... And this would be the one that I look at the AR250 hopefully at a boat show.
1) I like the blue, do not like the White Tower.
2) What is up with how the tower attaches to the boat? Gaps and pointy on the front and back of where the tower meets that mounting piece. How does that fold with the windowshield.
3) Screen.... C,mon, could of went up to the next size.
4) I like the wet storage, perfect spot for it. Alot of it now with the lower compartment.
5) Concerned about the table placement behind driver.
7) Would like to see Bimini Top up
6) Like the port Storage area and netting.
Found a vid here that seems to show this seating.No swim up seating on the AR250.
4 inches taller.The freeboard looks a lot higher.
As best I can tell, the videos they're showing aren't specific to one model; e.g. on the AR250 page the video shows several of the 25 foot models. Me saying the AR250 doesn't have the swim up seating was based on the using the compare function on the website (see attached screencap), but who knows if that info is correct or not either.Found a vid here that seems to show this seating.
AR250
View the new 2024 Yamaha AR250 25-foot boat. Powered by Twin 1.9 Liter High Output Yamaha marine engines. Yamahaboats.comwww.yamahaboats.com
Keep in mind the hull is deeper.Does anyone know where the additional weight of the AR250 vs Ar240 is coming from? Looks to be about 374lbs additional and the boat only increased by 6". I know some will be from the larger gas tank, but did they increase hull thickness on this model? Also, does anyone know if this model will have the swim up seating? Thanks!
