Clean out plugs
veedubtek
Punta Gorda, FL
Scout
So...when a clean out plug hasn't been removed, well, ever, and your boat is almost 4 years old, they look kinda like this:
I searched a bunch finding all the various methods of removing a stuck plug, and it just about scared the shit out of me. Well, I'm not sure it could've been any easier to be honest. I grabbed a spare dock line, and used the pre-looped end. Stuck it around the handle of the plug (after pushing in the release button), and then went looking for a praybar and a piece of wood. Of course, couldn't find one...but I have a 3 ton floor jack, with an oh-so-conveniently padded handle. It's about 4' long, so plenty of leverage. I had to put a good bit of weight on the end of it, but they both came out relatively drama-free.
And, as you can imagine, they look like new! Ish. Ok. Maybe they look like complete ass.
And of course, the tubes don't look much better...
So, obvious rebuild needed. Just so happens I like to plan ahead for stuff like this and had 2 kits ready to go.
Disassembly is easy enough. Remove 8 phillips head screws around the top
And then just pull the 2 halves apart
Now, the stench is just awful. Mine are now soaking in some mystery solution my wife concocted until tomorrow. Then I'll install the new parts, the Cobra EZ-locks, clean the tubes and reinstall. More pics to come then.
Murf'n'surf
Naples Florida
Ouch! You gotta pull them every time you come in. A little On/Off will clean up that nastiness if you weren't successful already.
I'll give a thumbs up for drinking a good beer. ;)
veedubtek
Punta Gorda, FL
Scout
Yeah, I plan on it everytime I go out. I can't believe the PO never pulled them. There again, I can't believe he only put 17 hours on in 4 years either.
Worst thing about this job...I didn't even finish one beer getting this far! I'm sure I'll have much better luck with that Sunday... got a whole lot more lined up.
jawsf16
Just be glad you got them to pop out. Those looked pretty gnarly...
Wow, those are the worst plugs I have ever seen!
veedubtek
Punta Gorda, FL
Scout
Note to self:
Self. If you're playing with your disassembled clean out plugs to see how they work, don't play with the release button or you'll be hunting all over the garage for a spring that can fly REALLY far.
davel501
Antioch, Illinois
Note to self:
I was just scrolling down from your 1 beer comment to say to keep those plugs in plastic bags while you have them taken apart or risk it becoming a 12 pack over 4 days job. :)
Zarrella
Lake City, Florida
Limited
Nice write up....good luck with the rebuild.
Big Shasta
Panama City Beach, FL
This would have been a good time to install the Tru-Locks from jetboatpilot.com. They correct the design issues with the internals that can cause them to release. The cobra locks do the job but they don't address the real problem.
You've gotta pop them out regularly. Just lay them crossways to dry over the hole. BUT, beware, they will drop in upside down and be hard to get ahold of.....ask me how I know this.
4x15mph
Downingtown, PA
This is a great write-up and a good reminder to everyone about plug maintenance. The plugs look real bad and it looks like the PO boated in the bayou. I am jealous that you are working on the boat and drinking Yuengling's.
Speedling
Cedar Lake, IN
SS
This time of year you go through less beer because you're so eager to get on the boat that you forget to drink it and keep working on it!
McMark
Monongahela, PA
Wow!
What is on off to remove the crud?
Zeus2013
Farmingdale, NY
It appears the PO was one of those who cared more for fun then the effort required to maintain the boat.
tdonoughue
The Woodlands, TX 77381
I pull mine out and lay them next to the hole, leaving the tray open.
Turns out it is really hard (!) to start the engines with the tray open, which means I never again try to take off with the plugs sitting in the holes unlocked... One time was too many.
Zarrella
Lake City, Florida
Limited
@tdonoughue
I do it the same way.....for the same reason as you.
veedubtek
Punta Gorda, FL
Scout
Left these things soaking for almost 2 days, and I've come to the conclusion they'll never look new again. I also finished this at the end of the day, after many, many beers, so pictures suffered.
Here they are assembled with the new rebuilt kits (kit is just the lower half and the rubber gasket):
Here's where you drill the hole for the EZ-locks:
EZ locks installed:
And finally, tubes scrubbed and scrubbed and scrubbed and scrubbed. And rebuilt plugs installed with locks:
Big Shasta
Looks good....Sooo much better. Bet it smells better too.
