Speedling
- Cedar Lake, IN
- SS
I am looking through all these threads and i am seeing a common thing overlooked or forgot to mention. A fuse!
If ran straight from the battery i highly recommend a fuse somewhere off the positive terminal for it. If the pump draws 10 amps then perhaps a 15 amp.
Some switches can act as a fuse but be sure that they are to function that way. I personally think if i do this i will wire up a new breaker to the dash. This will mean i don't need to go looking for fuses while the pump should be bailing water.
And if you think that 12 volt will short out from being in water you are wrong. I run electric brakes and leave it plugged in while backing in. Lights and brakes work just fine under water without popping a fuse. I use lights especially for night time retrieving. Your lights are most likely grounded to the trailer anyways.
In any case love the write up with pictures! Boat is in storage for now.
