On the water Help User Group - Join to Help or post @HELP when you are in urgent need
JDFester
Loganville, GA
Using a bungee sectioned tube rope to hopefully absorb small shocks; my tow point to his bow eye. Going about 8mph at 6900 rpm... not getting more speed for more throttle, so this seems to be about the optimum. Gone about 4 mi, likely about that to go.
JDFester
Loganville, GA
Got him home and loaded on the trailer. Thank you all!
swatski
North Caldwell, NJ
Sorry I'm late to the party! Glad it worked out!
The beauty of jet propulsion is that you can develop full thrust at any speed, so as long as you are not cavitating excessively - you can push the engine as hard as you want and will not damage anything.
The two things to watch and avoid is excessive cavitation and overheating the engines (caused by cavitation - inadequate cooling water supply) - keep an eye and touch the pisser streams - water should be hot but not scalding.
JDFester
Loganville, GA
I did check the water stream several times and it was always within the usual range. Just wasn’t used to seeing the exhaust. I’d done a few shot tows at no-wake speeds before, but this one was around 8 miles with a hungry and increasingly iritable first mate aboard (we were supposed to be meeting them for dinner and had just docked at the restaurant when my brother called and said he’d blown the belt on his water pump/alternator a quarter mile out), hence the interest in getting her to some food as quickly as reasonable.
I played around with the towing speed and found 6-8mph to be as fast as I could go without excessive cavitation; the boat in tow sits pretty deep in the water, so there was quite a bit of drag; actually looked like a decent surf wave coming off his boat at times.
Mando
Several member have suggested and I have finally gotten around to figuring out how to implement a method of allowing interested members to be notified when a user has an immediate need for help.
I have created a joinable user group named HELP.
If you wish to join the user group and receive notices when other members need help please click this link Account Preferences then click the Join box to the right of the HELP user group. If you want to leave the group you can use the same link then untick the box.
If you are a member who is stuck on the water or otherwise needs quick help to be able to enjoy your boat please include @HELP in the body of your posting which will alert all members of the group. (Be sure to put it in the body of the post NOT the title!)
I know that I could have used this feature when I was on a LS2000 that was sinking and when I was trying to find depth gauge parts before the Texoma meet for the SX230 I had just purchased.
Edited to add the direction to put @HELP in the body of post not in the title.
I just signed up.
Wisefam22
Lake Lanier ga
@HELP I'm in the keys lucky not far from dock but port engine had over heat light. I jumped in and made sure nothing was in filter by nozzle. I check plugs and from bottom of the boat as well.
No sea grass or sargasso left.
Could something have gotten sucked through filter? Had some smoke coming through pee hole right when I got light on tach and shut her down.
Scottintexas
Corinth, TX (DFW)
Smokung pee hole sounds like lack of water
If you dont see anything I'd start it up again and see if overheating returns
Chances are whatever was there washed away
Scottintexas
Corinth, TX (DFW)
I highly doubt anything got sucked thru your strainer screen
Ilmmct
Wilmington, NC 28411
Blocked pee holes ... caught me 1st time out this year ... after having the boat in the yard all fall and winter ... mud daubbers
Gym
Falmouth, MA (Cape Cod)
Possible you sucked some plastic that's blocking the screened inlet on the left inside of the nozzle? This would not be accessible through the cleanout ports but only from the back of the nozzle with the bucket in forward.
tabbibus
Lake Lanier, GA
Oh man. Stay safe my brother
Wisefam22
Lake Lanier ga
Thanks. Lucky we made it to side of mangroves where we were planning to fish. Havent cranked it back up yet. Was hoping something easy. Will update shortly
swatski
North Caldwell, NJ
The smoke would be steam actually, most likely.
Sometimes they overheat if turning a lot as it can starve a pump of water.
Wisefam22
Lake Lanier ga
We made it back. Most of the mangroves are a no wake zone. I hope I can get picture of passing another boat. 3 of my 4 trip through I have passed a boat. I'm talking inches between mangroves him and other boat each time.
We caught about 30 snapper today non of size.
Thanks for the help I wanted to make sure it was nothing more then I had found on here and what yall suggested.
Bones
Cape Vincent Ny
Bones
Cape Vincent Ny
This is one of the most helpful (pun intended) aspects of the forum. Just make sure you put the help callout in the text body, not the title.
And don't forget...anyone can join in to help out. Just go to the Account Preferences then click the Join box to the right of the HELP user group. If you want to leave the group you can use the same link then untick the box.
105416
