4x15mph
- Downingtown, PA
I am trying to push my steering cable through the hull but it is either corroded or it is on their with some 5200 on the inner hull fitting. I have tried to hammer the fitting through with no luck.
How do you take this wicked (curse, another curse) off? Any ideas for getting this piece through?
Here is a pic from the outside (picture #1) which has the nut removed. The other pic is from the inside and that nut that you see is jammed up inside the fiberglass. I can't get to it although I may cut the cable on that side and use the O2 sensor socket that I picked up from Autozone to see if I can get any grip on that nut. Loosening the nut will not do anything about letting the fitting come through but maybe it would free up whatever is seized before the nut turns.
Please help with ideas. Are there solvents that really work with 3M 5200 (if that is even what is on here)? I have soaked this with pB blaster for the last 3 days
