Replacing the trim on our "storage closet" door opening
itsdgm
I just got the final invoice in the mail yesterday which had shipping charges on it (and probably taxes too since I'm in ca). The total for me was somewhere in the $17 range including everything.
ratchetdu
Las vegas 89148
SR
Took the time yesterday and piece is installed. Super easy and looks great. The thought of not getting sticky gooey stuff on anything or myself is awesome...
Scottintexas
Corinth, TX (DFW)
it's just beautiful ! You didn't mention how easy the installation of the new strip was,
itsdgm
@Julian looks great. Thanks again for the heads up on where & which on to buy.
Putting on the new strip was SIMPLE! Where the fiber glass was a little thicker I gently used a rubber mallet, but that was really overkill.....but I was expecting it to be harder so I had it there.....simple...really simple!
Lspeedss
Powhatan,VA. 23139
Looks great
Topper232
Marlton, NJ
Limited
Just ordered mine as well. So, no glue for this strip? The metal edge holds it in place?
Thanks
justason
SWAG Forum Lead
Thanks
I installed mine 2 weekends ago...press into place.. Only snag I had was my cutting tool wasnt sharp enough to make a clean cut thru the metal band.....easily corrected.
Scottintexas
Corinth, TX (DFW)
Magic
Scottsdale, AZ
well then, this is a must......
Thanks!:winkingthumbsup"
jdonalds
Redding, CA
I did the clean up job like the OP. GooGone and alcohol to prep the surfaces. I kept the Yamaha stock trim that took a while to clean the inside of the messy glue. I nearly filled the inside of the Yamaha trim, pushed it in place around the door opening, and taped it with blue masking tape to hold it in place. It's been holding up for 2 years so far.
waterboy
Holly Springs, NC
@justason I got the info off of another site a while back for the engine hatch seal. It worked very well. A bit thicker than the OEM and seemed to seal up better.
McMaster Carr p/n 93085k13 it is a 1/2" x 1/2" foam rubber seal with adhesive back. Cost is $0.66 a foot. I ordered 20 ft and had some left over.
justason
SWAG Forum Lead
Thanks for the lead @waterboy I'm surprised at the adhesive back vs a slot captivating the rough fiberglass edge. Did you adhere it to the hatch or the boat?
waterboy
Holly Springs, NC
The original was very similar to this and was installed "on the boat" and not the hatch. Removed it, cleaned up residual adhesive, and stuck it back down. Pay close attention to where the hatch actually contacts the boat as I recall some areas were not obvious and you could end up with gaps.
Topper232
Marlton, NJ
Limited
just ordered the new molding yesterday and it arrived today via UPS ground. Now I can get all of my little boat projects done this weekend.
justason
SWAG Forum Lead
the guy with the group therapy avatar says "Now I can get all of my little boat projects done this weekend"
I keep saying I'm going to dig that ditch thru the solid NC clay.....2 beers later...it can wait till the rain softens it up.....
Topper232
Marlton, NJ
Limited
It's good to have goals right? :D
