Video of Yamaha 275 Stern swim up seats
Scottie
Helena, Alabama
Interesting!
Ancient canoe
Denton TX
That's kind of cool. I'd buy that for sure if I needed to replace my ladder, but I don't think I'd ditch a working ladder for it.
bolivas
Prospect Valley, Colorado
Here is the link. $1393.38 for everything needed for two seats. I would think you would want some sort of backer inside the hull though since other boat models were not engineered to attach these. With that said, you would probably need longer bolts (Part #39) if you were to put the backer plate...... Cool concept, but the juice is not worth the squeeze......
mark_m
Columbus, OH
I agree. I like to sit on the square throwable in the water at the transom.
ThatJeepGuy
Brooksville Florida
If you shop around I’m sure you could find a little better prices. I payed less than $500 for everything (one seat not two)
ThatJeepGuy
Brooksville Florida
Did you add any kind of backing plate inside?
Was it hard to get to the inside part to connect the nuts?
It’s not impossible but not easy. After removing the tray at the cleanout ports it’s a far reach to get to the aft bolts. I used a 1/4 aluminum backing plate and drilled the holes slightly smaller. I threaded the bolts through the backing plates so I didn’t have to hold the actual bolt as I was finding the hole location. There’s no way I could have reached the aft bolts
There’s a little more info and pictures in this thread
