2015 242 limited S Rod Holder
nydave
OK i know it has been discussed many times. I have read ALL the posts. I have also ordered and returned 3 diff rod holders recommended trying to find one that fits. I am looking to mount rod holders to the tower of my 2015 242 LS. The tower is 2 3/8ish. everything i find is 2" and under. Has anyone successfully ordered and mounted rod holders on the tower of this boat?
Patman941
No luck? I’d like to purchase some rod holders as well and have the same concerns. If anyone can recommend some that have worked and withstood the test of time, please advise. Thanks all.
Patman941
Do you have a link for the ones you purchased? Let us know how they work out when you give them a true water trial.
JeffVans
Zion Crossroads, Va
I haven't installed them yet, but plenty of other people have. Here's the links. Really fast shipping and the actual products ordered....not SleazeBay scams. lol
Patman941
Thank you! What type of boat do you have? Reading the description it’s for a T-Top, but it also says the clamp adjusts every 18 degrees. Just want to make sure it will work on my wake tower?? Thanks again.
JeffVans
Zion Crossroads, Va
2016 242 LSE
4jrv256k
AR192
It depends on what type of boat you have basically I’d like to purchase some rod holders as well and have the same concerns as fishing equipment uae. I bought Aluminum Fishing Rod Holder (LFH058) but it is not so good as I wanted because the flag holder is big enough for a rod handle.
4jrv256k
AR192
It depends on what type of boat you have basically I’d like to purchase some rod holders as well and have the same concerns as fishing equipment UAE. I bought Aluminum Fishing Rod Holder (LFH058) but it is not so good as I wanted because the flag holder is big enough for a rod handle.
