__ScottyDont
- Leonardtown, MD
- SX
So after buying and buying all winter long, I figured its time to kick off installing all these winter mods for the boat, especially with the beautiful weather in Maryland this weekend.
The list is sort of in order as I intend to execute but I may not get all the way through:
A lot of work, but should be doable, I won't be putting in for probably another 2 or 3 weeks. Just enough time to get the rest installed. Should have the Scupper and Perfect Pass installed tomorrow. Next on the purchase list is a boat lift which will probably be this coming week and also a sound system from Odin at Earmark right behind that! Should be calling it quits following that.
I'll get pictures up ASAP!
- Overhaul the Pier (strip everything but the poles) - Installed
- Stainless Scupper - Installed
- Zinc Anodes - Installed
- Glove Compartment Spring - Installed
- Closet Rope Hooks - Installed
- Tower Mounted Flag Holders - Installed
- Twin Battery Charger w/ In-Deck plug - Installed
- Sound Proofing (Dynamat Extreme) - Installed
- Perfect Pass - Installed
- Boat Lift - Installed
- New Audio System (Fusion Deck\Control w/ JL Sound) - Installed
- Power System Overhaul - Installed
- Closet Shelf
- Bottle Opener - Installed
- Location Decal and strip warning decals - Installed
