15 242 trashcan
john94si
Orlando, FL
SeaDoo
What did you all use for the trashcan that goes next to the passenger seat? I need to pick one up that fits well in there.
Also port potty which one is good for under $100
MrMoose
Calgary, AB, Canada
Hi @john94si . Good post. There have been similar ones regarding porta-pottties, but nothing regarding the trash can on the 2015. Regarding porta potti, I bought one (and have never used it) to have on hand for the Bimini trip. I went with the low-cost-easy clean-up approach. I got the type that's simply a toilet seat/lid that fits on top of a 5 gallon bucket. I use a bucket that has the same diameter as a 5 gallon, but is half the height so that it can be placed on the "seat" in the head compartment. I use trash bags and I'll pre-load the bag with kitty litter to make for an easy clean-up.
As far as a trash can goes, I haven't found anything that I think is great. So far, I've been using an office style rectangular open top plastic can from Home Depot. I use two small 4-inch bungie cords to hold it in place. It works fine, but is at risk of collecting rain water. It's not pretty, but it works.
Williamsone46
Lehi, UT
255XD
I've looked for one but yet to find one that fits and looks good.
The Budnick's
Carroll, OH
I found a suction cup grocery bag holder that works well on the inside of the head door. Trash is outta site and wind when cruising.
BoaterGuy
This is the one I have in my 13' 242LS. It works great for us. There are two different ones from Dometic that work but this one sits lower which allows more headroom. I've even had a 6ft 7" friend use it. (It wasnt fun for him but it worked)
The one I have:
http://www.amazon.com/Dometic-301096202-Tan-Portable-Toilet/dp/B001EJRGYE/ref=sr_1_1?ie=UTF8&qid=1453810523&sr=8-1&keywords=dometic+marine+toilet
The other one:
http://www.amazon.com/Dometic-301097606-Portable-Toilet-Gallon/dp/B0050EFHWW/ref=sr_1_2?ie=UTF8&qid=1453810651&sr=8-2&keywords=dometic+toilet
billyb
St. Louis
Limited
I looked long and hard for a trashcan. What I came up with works awesome and cheap.
I got a small/medium plastic tub used for storage. I remove the lid and just toss the trash in and put the lid back on when under way. It fits either in head or under the starboard rear seat.
When I get back to the dock, I just empty it out and give it a quick rinse with lake water for any liquids the got in it.
Ronnie
SF Bay Area
I went with a domestic porta potty. It was a little over $100 at west marine. The non marine version was under $100 but didn't include the mounting brackets which where around $30 if purchased separately. If you don't intend to mount it the lovable loo (toilet seat on a bucket ) should do fine.
No ideas on a trash can as my boat is older. It has a combing area with a net on the passenger side but it's a small area which is covered when the seat is configures as a lounger. One mod some have done is to remove a cup holder and use its space as a pass through to a trash bag.
Jacob hahn
I use a diaper trash can that fits neatly in the side net. The lid is perfect and it's easy to empty.
Bill D
Prairieville, LA
For an Emergency Only! situation, the Luggable Loo works perfectly fine, and I like that in a real emergency I can use it as a bailing bucket.
For those using the 5 gallon bucket solutions, the Double Doodie bags work really well. They have a gel in them to keep smells and cleanup to a minimum and there's two bags. The outer bag has a heavy duty ziplock closure and just closes around the waste bag.
tdonoughue
The Woodlands, TX 77381
For a 'trash can' I get the white kitchen trash bags with the cinch thingy on them. I have a leftover velcro dockline tie that I wrap around the little post on the port side windshield (where it meets the dash). The bag hangs there next to the head compartment. When it is time to fly, I open the door, swing in the bag and close the door (leaving the bag still attached). When we stop, open the door and swing out the bag again. Works great for me.
David Decker
Atlanta, GA
I am going to try this "Simple Human" can from The Container Store. It is quite small, so it won't work for everyone, but it is in a convenient spot and it doesn't intrude on the passenger's space too much.
If you don't generate a lot of trash, it might work for you.
http://www.containerstore.com/category/simplehuman?productId=10033714
I'm going to add some SeaDek padding to the back and bottom surfaces of the can so it won't rattle/buzz and will sit more level. Right now, the front edge of the can is about 1/2" up off the floor.
It is all stainless steel and plastic, so hopefully it tolerates the harsh environment well enough - I'll post back my thoughts after using it for a while.
shane hric
Hobart Indiana
Oh Hell...be careful on here with the porta-potty remarks...ha ha ha! I started a conversation with a group with the same boat and most thought it was gross and the wives chimed in! I haven't looked into the trash cans yet, but I like the Thetford Curve porta-potty, but I'm still doing my research! Hope this helps!
tdonoughue
If you're not willing to look into the trash can, certainly don't look into the porta-potty...
(sorry--couldn't resist)
So how has this worked out for you....we bought a cheap one with a lid, and it isn't working well for us as the lid lifts off to easily.
David Decker
Atlanta, GA
@Julian - it is working really well. The only issue I had is that that area where I have the can isn't level - there is a gap at the bottom front edge. I solved this by attaching a couple of self-stick rubber feet, about 1/2" thick to the bottom of the can. I also attached one to the back of the can, near the top edge. With these little rubber bumpers in place, the can is level and doesn't make any noise and stays put even in the roughest chop.
This can doesn't have a huge storage capacity, but if you can live with the smaller size, the quality is great and it stays put and looks pretty good as well.
Does stuff blow out of it at speed?
David Decker
Atlanta, GA
I use plastic liner bags in it. If there is nothing in the can, the bag can flip out (inside out) at speeds over 40mph or so - it only happened once though. If there's anything even a little heavy, no problems. I've never had anything blow out of there, but I guess if it was full with light stuff on top it would be possible. Not an issue so far for me, though. I really like it!
Nick Hughes
Columbus, OH
Is the space next to the passenger seat with the net hooks for a trashcan? Been trying to figure out how to use that net for there, always so loose, this would make sense. I just have mine on the floor of my head right now, no issues with my beer, er pop, cans blowing out.
MrMoose
Calgary, AB, Canada
I use that space for a trash can, bags, and wipes. I use mini bungee cords to hold the trash can in place.
