2009 212x navigation lights (replacements)
justason
SWAG Forum Lead
I understand there are a lot of variations on navigation lights on these boats thru the years. Mine recently corroded and needed replacing. Yamaha OEM lights are $85 EACH ! found these on Amazon for either $38 or $44 depending on source. they are for a pair, they are LED..and.. THE MOUNTING MATCHES for size envelope of the OEM screw holes and cutout. (for this style).
https://www.amazon.com/gp/product/B01D3ID6S8/ref=ox_sc_act_title_1?smid=A10KONGIV6WPUI&psc=1
justason
SWAG Forum Lead
Didn't know that some boats went with side lights vs one center mounted one in the bow.
These came as a clear lens and no Red/Green marking designation.....Powered up in the lab...THEY'RE WICKED AWESOME !!
Seadeals
Greenville, South Carolina
Those are very cool! I changed the bulb out to an LED bulb on my original lights; but the contours and lens on that is much more snazzy. Nice find.
Snofire
Appleton, WI
Do you know if these would work on a 07 Sx210?
justason
SWAG Forum Lead
Tag @Bruce he knows when body styles changed. If you have the side markers like mine/these i’m sure they will fit. I believe the link at the top has dimensions on it
Snofire
Appleton, WI
@Bruce . Would you know if these would work?
Bruce
Royal, AR
@justason I did not realize that the 210/212 lineup had side lights instead of a single bow light.
@Snofire I believe you and @justason have the same hull so they should work as well for you as they did for him.
Snofire
Appleton, WI
@Bruce Thank you for verifying. I'll get these ordered up today! Have alot more projects in store for the boat.
