Skin6061
My 2012 242 started misfiring on startup. So this is kinda odd. Been using the boat all summer and no problems. Toom the boat out started up and ran just fine off the trailer and head to the first beach. Leave from the go.to the marina have lunch and when we leave no issues. Go to the last beach and hangout a bit and when we leave only one engine fires up. Get the second engine to fire but one engine sounds like it's misfiring. Shut both engines off. Turn off all batteries and wait ten min to clear codes and reset ecu. Now this is where it gets weird. Fire the port side no problems. Fire the starboard side it fires no problem but the port side start misfire. Shut off port and troll at idle to boat ramp. Wait a few min fire the port side and then the starboard develops a misfire. This goes one another two times alternating misfire. Checked voltage on the guage with the running motor and it was at 13.1 volts. Tried one more time and the motor fired and the other one did not misfire and everything was back to normal. I assumed I had a voltage drop when firing the a motor that caused the other motor to misfire. I was thinking a dead cell in the starting battery. But with the guage showing 13.1 volts Im thinking I may be missing something.
I have three batteries one start battery one house battery and one battery for my amp. All on there own switch and I use a battery maintainer between lake trips.
Has anyone ever experienced something like this before and can guide me to what may be the cause of my problems?
