Steinwandj
- Limited S
I know this topic has be discussed at length, but I know there is someone out there with the direct answer to my question. Is there a way to have both engines use one APS (temporarily with maybe a double throw switch) and if so which wire is the output wire from the APS?
My thought is that these act like a potentiometer with a bios voltage (input) and an output. If I take the output from one APS and connect it to both engines they should be both receiving the same Accelerator position and thus syncing the two engines. Is this possible without messing with the ECM?
