2015 Yamaha 242 limited S problem
Mech4niq
Hello forum members. Hoping for some advice after scouring the forums and coming up empty handed.
My 2015 242 Limited S is showing CAN1 and CAN4 errors on the CONNEXT display. Morover, with the House switch ON, the starboard tach keeps performing the sweep test every 2 seconds while the port tach is not moving at all. I tested the batteries and found the House battery bad so I replaced both for good measure, cleaning all of the connection in the process. The problem remained. I then started checking fuses and connections at the helm, the battery compartment and the engine bay. Everything is bone dry and corrosion free. I disconnected the transducer to see if it could be causing a problem and the errors remain. Any ideas?
I should add that a lightning struck a tree right next to the boat sitting on the trailer a week ago. This is the first time since then that I tried to start the boat.
Also the port engine runs rough and will not throttle at all.
Did you end up getting this fixed any how ?
The Boat is with a Yamaha dealer/shop since June. They did diagnosis and were having problems connecting to the engine ECUs along with the symptoms that I described. I am awaiting an update. I have a new thread relating this problem here 2015 Yamaha Limited S problems which I will update once I have something new to share.
Why are you asking?
Saw you were in NJ and was just reading the other posting. I have a pair of ecu's from a 2014 242 if you need to "try" different ecu's to verify. Should work the same as it's the same engine. I'm in NJ as well so let me know if I can help.
Verify the part numbers. Yours is a non connext system, his has a connext, could be different. But very nice offer. If they are the same it would be nice to make sure its actually needed and they are not guessing
