2016 Yamaha 242 Limited S Audio Upgrade
Dalesy
I've had a local audio installer add 2 -800 watt arc amps, 2 - 12" wet sounds subs and 2 - 6" kicker tower speakers. Wish I would have spent the $$ and wet with bigger wet sounds tower speakers but that can be next on the list.
Question i have is that I've heard good things about the NOCO Genius 2 bank on board charger so purchased and installed this evening. The plan is for it to recharge 2 - Kinetik HC3800 power cells that are responsible for providing power to audio. I hooked each set of leads to each Kinetik battery (batteries connected in parallel) for audio and once plugged in get a nasty humming noise from the speakers. It doesn't sound normal to me. Any ideas on what i am doing wrong??
PS - Original batteries for start and house still on board and are running what they were designed for.
Mainah
Chapin, SC
Two batteries connected in parallel is one bank not two. Only use a single bank charger for that setup or pull the fuse from one of the leads from the current set up to turn it into a single bank. Those “power cells” are really giant agm batteries but about 35% bigger than group 31 agms and designed for higher amp loads. They will take awhile to charge as a single bank but have plently of instant amps once charged.
