- Tranquility Base
- FSH Sport
While I am sure you think your tone validates your solution, it does not. The cables had issues all the way through, actually one sided, it is known problem from Dometic whom manufacturers the cables. It was more than corrosion and I always suspected Manufacturer Defect. I didn't spend a thousand it was a few hundred, and the new cables work flawlessly. Additionally Yamaha has issued a NO SELL on boats right now that have cables and a mass recalls, dealers have been instructed to not sell/Deliver the models with steering cables, until the parts are replaced. Dometic has had issues with their cables for years with quality. It is a fairly seen problem by many. The most current one could be also a safety issue. I personally have done mine and helped multiple people replace theirs and the issue is always the same.
Rather than make do with a component that could have issues at anytime, and something so important as steering, I would prefer to replace them, which I did. Now with the issues that have been happening with Dometic, the manufacturer of our steering cables, I feel that replacing was the prudent option. Additionally, when I replaced mine, they were still very hard to get and if something additionally happened I may have been down for the season.
And while I personally replaced mine, for those whom need them/want them replaced it is covered under 1st year and extended warranties, especially now as more information comes to light about Dometic and their product.
So, the replacement cables you installed, are they made by Dometic ? We’re they an upgraded / fixed cable?
