Wishfull1
- Canal Fulton, OH
- SX
Man! They’re proud of those !
There is a reason anyone with a winch on a SXS throws steel cables away and replaces them with synthetic. Steel rusts, you get slivers if you handle it without gloves. And when it does break, the recoil can literally slice your skin wide open. Where as synthetics don't have recoil, or what little there is, will never hurt anyone.I went ahead and replaced my winch with a larger winch that has a steel cable. I don’t have a link, as it kinda fell into my lap, but the peace of mind is well worth it.
I moved my stop back to meet the boat as you described because of the same issue. I didn’t notice any change in trailer balance or anything but I never actually weighed the tongue.Thanks for the input guys.
This is the original strap on a 2018 SX195. I typically lightly power load with the tops of the fenders just above the surface, any deeper and the boat doesn't center up properly on the bunks. This leaves about a foot or two to crank.
Another possible contributing factor to the early demise, is the strap is under constant heavy strain. The bow is "pulled down" to the roller. The bow will come off the roller a good 4 inches when the strap is loosened. The dealer has maintained this is normal and no adjustment is necessary. I have also seen others on the forum with the same issue.
I am not sure how the adjust this for a better fit. Perhaps move the whole stop back to meet the bow at a better natural "resting" position?
Awesome, thanks! I will give that a try when I replace the strap.I moved my stop back to meet the boat as you described because of the same issue. I didn’t notice any change in trailer balance or anything but I never actually weighed the tongue.
Mine still comes off the roller a few inches when I’m floating and ready to launch but out of water the eye stays right on the roller.
I'm sorry you misread the post, unless someone else stated it, but we never said they don't stretch. The point with synthetic, as they can be stronger for the same diameter, and have "less recoil" Factor that with the recoil of a synthetic line, even if at the same force, would not rip your flesh open like steel could. (remember the days of throwing a jacket over the winch line to reduce recoil) Your video proved my point, that synthetic line would not have hurt anyone, and it had tons of force on it.Gentlemen, I have to disagree with about synthetic rope not stretching under load… to me that is patently false. Synthetic ropes are just as dangerous as other lines if they break
This company has a good reputation in the off-road world. Company is USA owned and provides quality sourced products.
Rhino USA Boat Winch Strap
