WiskyDan
- Jackson, WI
- 242 Limited S E-Series
-Loading begins for me once I begin lowering the boat down. U can walk around it just fine when fully inflated for the most part.
-Installed with the help of friends that also have air docks and no frame kit. I have four points to hold the the air dock in place while pulling on/off.
-I will never remove my bladders because all barnacles on the bottom would cause holes when dragging across the dock.
-I have had mine for 5-6 years with minor issues, u will learn as u go for sure. Getting it setup right is a process, meaning the positioning of the air dock and the lines securing it to the dock, getting the boat to sit properly so u can flush, etc.....
Thank you for the reply. I’m guessing that you don’t have to worry about ice so you can leave it in the water year round?
