Ronnie
- SF Bay Area
- Limited S
long story short, I had just installed the drain plug and was about to launch when my cousin started walking down the ramp so I removed it hoping to let more water drain while I was on the boat ramp. Basically, I got distracted, Before launching I asked my very close friend who was holding the stern line if the plug was installed. He looked and said yes, I said are you sure? He looked again and Again he said yes. Fast forward 15 minutes and 5 miles, we stop to take in the scenery and I notice the bilge pump is on and staying on. Look in the engine compartment and see water over the bilge pump. Check the ski locker, the plug was out, and it is half full of water. Spot a nearby shore and head right over to beach it. Watched the cooling spouts work on the way there so I know those connections are tight. End up checking the drain plug next and sure enough it was unscrewed and about to fall off completely. Not blaming my buddy, I'm the captain and owner, responsible to make sure the drain plug is installed and for all souls aboard my vessel.
We ended up having a great day on the water in part because of what I learned on this site and the other one. the generic lesson is a basic one that applies in many situations though, when things go south don't panic, right away. If you are boating get to shore/get everyone to safety, if you can. Now for me, when in doubt visually verify that the plug is in correctly myself.
