Amp not turning on my ar250
Amar Nanduri
SeaDoo
Challenger
I replaced the factory stock amp HTX 4 with a HTX6 amp. I tested the new amp as working. During installation I forgot to turn the main battery off and both the power wires (that go into the amp ) touched and sparks flew. These power wires are not connected to the amp but lying free. After that I switched off the battery mains and connected the amp. But the amp would not turn on now. There is no power flowing into the amp. I verified with both amps with same result. I touched the power wires together for an instant to see if soaks will come but none. I opened the fuse box next to the main battery switched and checked the fuses and they seem okay. The connext works but jo power to amp. How do I troubleshoot this ?
thanks
Amar
ripler
Just south of Pittsburgh
MasterCraft
I'm not familiar with the factory wiring, but there is probably a fuse dedicated to the amo and it may not be in the fuse box.
RobbieO
Sacramento River Delta
212SE
I also have a connext system and a dedicated amp fuse. Mine is located in the engine compartment behind the fuse panel in the battery compartment. You have a Seadoo, so no idea where is would be. But it's big and stand alone, so you should be able to find it no problem.
Amar Nanduri
SeaDoo
Challenger
Thanks Robbie. Can you send me a picture of where your amp fuse is. Mine is a ar250. Thanks
Amar Nanduri
SeaDoo
Challenger
Are you talking about this ? I replaced all the fuses here. No luck. Amp would still not power on. So I think I might not have found the amp fuse yet.
RobbieO
212SE
So if you open up the rear seat hatch, mine is immediately on the upper right behind the fuse panel in your picture.
Amar Nanduri
SeaDoo
Challenger
Which one in the picture Robbie ? Thanks
RobbieO
212SE
Not in those pics....you have a 252 so probably in a different location...mine is an in line fuse between the battery pos+ and the amp, in the engine comp....mine is a 212SE
RobbieO
212SE
On my boat, it's mounted on the opposite side of your battery switch. The amp power runs directly to the battery switch, so follow a rd lead that goes into the engine comp. Again, I have a different boat, but probably wired similar.
adrianp89
Tampa Bay, FL
252SE
Use a DMM and start checking the wires. Is ground good? Is power? Is remote? Use DMM to start checking continuity in fuses.
Amar Nanduri
SeaDoo
Challenger
Does the head unit come on?
Did you connect the remote wire to the amp(usually blue and/or blue&white wire).
Did you check the fuses on the Amp itself?
Yes. All done. I ran a separate power cable from battery to amp and it fires up, connext turns the amp on and sound comes. I narrowed it down to the original red wire issue. Might have burnt off somewhere as I can’t find any fuse. For now I ran an auxiliary cable from the blue sea distribution block to make it work.
My amp cables hav dedicated in line fuses.....bet they are there....just hiding well!
proplessdancer
MN
AR195
probably fried the original wiring when it shorted out. ive seen wires completely start on fire from that sort of thing. be sure to put an inline fuse on the new power cable. better to blow a 0.25 fuse than expensive amp
RobbieO
212SE
Did you check your owners manual for fuse locations?
Amar Nanduri
SeaDoo
Challenger
That’s exactly what I did
Amar Nanduri
SeaDoo
Challenger
Couldn’t find it in the manual for the amp. Whatever fuses are present in the fuse box , I replaced every fuse
Amar Nanduri
SeaDoo
Challenger
One thing I noticed is that the wiring (speakers were as well as power cables) are not tinned and this surprised me. It’s pure copper and I fear I will have to replace all wiring in a few years. I am surprised Yamaha used all copper wiring.
adrianp89
Tampa Bay, FL
252SE
It's not an issue.
RobbieO
212SE
If the wires you touched were 2,4,6 or 8 gauge, there is an inline maxi fuse somewhere. The fuse panel would not be able to handle the amperage. You'll find it. Maybe call the dealer or Yamaha Customer relations. You can ask a tech there. 1-800-962-7926.
