bttally
- North Florida
- FSH Sport
I have a 2017 AR190 that I have put over 100 hours on it in the last year with no issues at all. We usually run long distances when we are out and there have been several days where I have run two tanks through it in one day. I run 90% in salt water and I have run all the way from St. Marks, FL to Orange Beach, AL in segments to give you the idea of what I use the boat for. The last five times out running long distances wide open for over 45 minutes the heat alarm comes on. I shut the engine down and let it cool and then run again at lower speeds with no issues all the way home without any further alarms. After the second day I bought a temp gun and checked temperatures all over the engine and most were under 170 with only a few areas reaching 200deg on the bottom of the exhaust manifold. My most recent trip had the overheat alarm on after only 5 miles and only the last mile at WOT. This time my gun did show temperatures between 210-225 in several areas.
I do flush after every trip. I have ribbon delete and L13 cone installed. The intake grate is clear, the tunnel is sealed, cleanout plug seems to seat tight, and it has a strong flow out the pee hole while underway and while on the hose.
Thought 1: I installed Lectrotab Trim tabs back in March and they work great on the little boat, but this issue started since the install. Trying to trouble shoot I have left them retracted the last two trips and I still overheated. They hid up under the rear shelf so they do not drag when not in use. I will have to post more about the install once I figure out the overhearing issue. I assume this is not the cause.
Thought 2: After the third time with an alarm I pulled all of the heat sensors. I pulled the temp sensors(each has a different name) in the exhaust, the two from the motor and then the thermostat off the back of the motor. All looked clean and new and tested fine in a pot of water following the testing steps in the maintenance guide. The thermostat had some buildup from salt around the seal, but it cleaned easily and tested fine by opening at the right temp in my pot on the stove. I reinstalled everything and ran it on the hose 6 times with salt away to clean the rest out. It still overheated and this is when I had the higher temps with the gun.
Thought 3: Since my overheating has only happened after running WOT I started inspecting the impeller after reading on this forum about cavitation. From the back it looked fine but after pulling the pump I now see that the impeller has some nice dings and the impeller housing has a decent gouge. I guess I got a nice rock at some point. I have not noticed cavitation, but is is possible that this is causing my overheat at WOT? I know it has a strong flow through the cooling system while on the hose and while cruising but I don't know that I have checked while at WOT.
I ordered a new impeller and housing last night so once it arrives in a week or two I will be able to test it out, but I want to know if I am missing something else obvious while I have everything taken apart.
