Battery relocation - oops/fix
Jim Crane
Paoli, PA
Moved battery and added a switch.
But then I realized I had put the battery right under the drain for the cup holder, so I had to add a drain tube as well.
Before:
105500
After:
105501
Another angle:
105507
Then added a drain tube and followed the cooling line down to bilge pump:
105506
That is typically all Yamaha does when they add drain tubes! (Just drain to the bilge). The only exception I've seen is with the swim step cup holders...where they actually added little drain caps on the lower steps for drainage (which is good since they get a lot of water in them).
