OrangeTJ
- El Dorado Hills, CA
- Other
- Other
For some unknown reason, my bilge pump all of a sudden won't come on. Flipped the switch, it lit up for 10 seconds or so and then the breaker popped. Reset the breaker, does the same thing. Then, breaker won't reset and switch doesn't light up when turned on. No movement at the pump. Bilge is dry. Pulled the pump to check the screen - clean. Any thoughts?
