Billy Marlin
- Tallahassee, FL
- FSH Deluxe
2 Sundays ago I put my boat in my new covered slip but noticed it had a bunch of water under the console changing room area. Thought this was from all the rain we had prior to me putting it in the covered slip and not really understanding the drain plugs in this boat. Lets just say they need a whole section added to the owners manual on how not to sink your boat!! It sat a week and I asked some other members on here about the drain plugs so I had some things to check out when I got back down to the boat. I did not leave the bilge on simply because I thought every boat had an auto bilge that would kick in if water got too high. So the boat sat in the water all week and did fine but I needed to install my thrust vectors so pulled the boat. Did all that drained the boat completely and dropped her back in the water. This time made sure all drain plugs were closed and put it back in the slip. Left the bilge pump off because I wanted to see if I had any water coming in from somewhere else and since it sat a week before it would be fine.
Rolled into the campsite on Thursday night of last week to find the motor compartment was half full of water along with the front console area. Kicked on the bilge and got all the water pumped out pulled the air intake filter and got the water out of it. Checked my oil and does not look like water got into the motor at all thankfully. Once I got the water out I pulled all the screws in the bait bucket holder and cut my beautiful silicon job so I could get to the hull. FYI I am only installing a few screws and leaving this so I can easily pull this in the future. Found water was slowly seeping in the right drain plug!! Another FYI unless you have long arms you will have to dunk your head in the water to reach the plugs. Turned the plug a little tighter and it only stopped the flow a little.
Pulled the boat out of the water and when I did it looks like the o-ring did not seat very well when I put my plug in. It was hand tight then a half turn more usually you don't have to crank these down to seat them. Also because these are plastic did not want to over tighten them left side was just fine.
So after looking at my bilge pump I realized it was supposed to be clipped in to the mesh screen and standing up-right instead of on its side. This was allowing the water to at least fill up 2 inches in the motor compartment area. Someone never snapped the bilge pump in its correct place!!! So I think this is why water was getting up to the front console area.
This morning I ordered 2 Garboard drain plugs and a 2nd Bilge pump with built in float. I looked at float switches but I could not find a single float switch that did not have horrible reviews. I am also moving my 2 trolling motor batteries from the rear port side to the front console along with amp and 3 bank charger. This is to deal with the boat having too much weight on the port side and too much moisture in this area.
