Do you have the hardware part numbers?I copied someone else's mod for mine. Basically just ordered two grab handles like the ones already on the boat at the back of the cockpit. I purchase from yamaha sports plaza in Seattle. If you go this route don't forget to order 4 washers and 4 nuts/bolts as well. It's an easy mod, just measure and drill four small holes. Total cost was around $70. Oh and don't forget to assure that the wiring for the nav light is clear before you drill and that you can reach the nuts/bolts of the handle with a wrench through the anchor locker.
That looks great. What size handle did you use? It looks like you got the handle without studs.
I'm not finding any $14 Stainless handles on Amazon...can you link to them?
Yep - those are the ones.
