captain seat will not swivel
Michaelbosco
I have an 2013 AR 192 I bought last year. The driver seat has never swiveled. just curious if any one knew any fixes or do I bite the bullet and replace the bottom of the chair. couldn't find anything in the forums. Thanks in advance
kgower
Buford, GA
222SE
Mine will turn but neither captains chair will slide forward or back. Might be doing something wrong.
biffdotorg
Pelican Rapids, MN
If yours is similar to the older 192, then you extend it out to slide.
RobbieO
Sacramento River Delta
212SE
No, the mechanism sucks. I have to get on my hands and knees to adjust either chair. Ridiculous
Don't tell my wife, but I have to move her seat forward and back for her its suck a PITA. Also, if you have it all the way back, you have to move it forward for it to rotate, otherwise it hits the gunnel and won't rotate.
RobbieO
212SE
Ya it may be time to pull it and soak the mechanism with WD40. Good luck.
Use something with a penetrant. WD40 works in a pinch, but it only does what it's name says...WD=Water Displacement
