sienaaof
Hi guys, first post on the board, long time lurker. Normally have been able to figure things out by searching but not this time. Having some issues with my 07 Yamaha AR230 HO
When I bought the boat last fall it had what felt like a bad cavitation issue, felt like a slipping clutch and could barely get on plane, I had swollen wear rings, missing sealant, and needed some impeller work and figured I'd replace the pump bearings while I was in there. So this past winter I got all of that taken care of.
I had my boat out for the first time yesterday and she did great, at first.....then right back to the old problem.
I did the normal prep for the season, changed oil, changed plugs, greased the intermediate bearing (cleared out old bad almost solid grease and replaced with fresh grease) pumping only 2 pumps into the hose. I took her out yesterday and it took off running perfect for the first two times starting from a dead stop to full acceleration, was very happy. I then proceeded to be stopped/ slow in a no wake zone for about 10 mins and decided to head back, also at this point I hit the bilge pump and a lot of water came out, ran for about 5 mins or more straight. I then tried to accelerate and it was doing the same thing as last year, felt like a slipping clutch and couldn't get onto plane, had to limp it home.
My thoughts are that it is the intermediate bearing housing/seal is shot and allowing water past at no/slow speed and also creating cavitation under power. I need to get the boat out again and watch everything to see if/where water is coming in from. What does this sound like to you?
Also how hard is it to "move" the engine(s) forward to get access to the housings? I see in some posts you it can be moved forward and not removed, do I just need to remove the motor mount bolts/exhaust and scoot it forward a bit?
I'm also having a problem on my starboard engine running rough at idle and it can't keep the "no wake" setting. Could be the bearing? Injector?
I'm bummed that after all my work this winter I haven't solved the problem and I'm looking for any help I can get! Thanks guys.
