Connext Touchscreen
Jharrisok
Oklahoma City
I just bought a 2017 242X and the touch screen on the connext system doesn’t seem to be working. Is there a way to turn the touchscreen on and off or do I have other issues?
Neutron
New Bern, NC
It should power up when the key is on there is no on off switch
Chaunceybland
Memphis
My Connext screen starts when I turn on the house battery, no key needed.
Jharrisok
Oklahoma City
It powers on and everything works except the touchscreen feature. You can only use the knob To get through the settings.
Neutron
New Bern, NC
Hold the system button for a bit to enter the diagnostic mode. There is s screen reset option i believe
Jharrisok
Oklahoma City
Thanks for the advice! I was able to rest it and get it working but the accuracy on the touch screen is way off. I tried calibrating it but still not good. I’m getting pretty proficient with the knob. 🤷🏼‍♂️
DRAT
Sachse, TX
i have the same issue with touch screen calibration. honestly, and i'll qualify this by saying i'm still a new owner, but on balance i think the Connext system/screen is pretty bad. it's not very intuitive, the calibration is all over the place and there are too many screens, selections, buttons and redundancies.
Serg
Having also same problems with my 2016 Yamaha 242 Limited S E. I have already tried turning the batteries on and off but still no good news. I unplug the screen from inside the boat still NO. System RESET and calibrate..... but it still irresponsive. Is there a computer that could hard reset and reboot the screen so that it can restart the monitor? So that touch screen will be responsive? ( only menu or upper part is responsive but the mid and lower part of the screen does not respond ) Thank You
Weeb
Denver NC 28037
I was having that problem and had to replace the whole unit.
Serg
Ouch, around how much that its costs? Did you try also disconnecting battery first the connect again? Then when you replaced then touch screen, did the hour engine reading goes back to 0 hours?
Weeb
Denver NC 28037
I got it covered just before my yes warranty expired. I think I looked it up and it was around $2500. It was on back order and took about 4 months to get. My hour meter remained correct.
Serg
Thanks much, with that expensive unit. I just use the joystick
cjordan
I have a 2018 AR240 and my touchscreen sensitivity is not working. Earlier in this thread I see reference to a "system button" to enter diagnostic mode. I don't have a system button on my unit. Is there some other way to get to diagnostic mode?
What buttons do you have? I thought there was a SYS button on them all....(but never studied that closely)
cjordan
I figured it out. It's the SyS Ctrl button. Thanks
