mrcleanr6
- new jersey
- 275SD
Yes victron has a couple things. The gauge which uses the shut. This is the ones i mentioned before. The 702 and 712. Both you can also read via app and bluetooth. The other is just the snart shunt. No gauge with that. Shunt only that you can pair with your phone.
I could just swap the 4 (2x2) Group 29's I have now for 4 100Ah LI's and save over well over 140 lbs... that one beach barbie... and a cooler full of beer... its the $350 per battery that slowing me down
might be a service life play here as well.. I (the AR210) gained about 250 Lbs with this MR-1 conversion including the full fuel load weight. This would offset most of that and if I went with 2 slightly bigger LI's i could get 200Lbs back
