- Tranquility Base
- FSH Sport
After having my boat for a second and full season, I found that can get about 10 miles out of my trolling motor battery, or about 6 hours of use at 1.8 mph, which is not enough for my average day of fishing which is 10-12 hours. So I was messing around with idea of replacing my trolling motor battery SLA batteries with lithium batteries, and possibly my house battery as well. I haven’t seen a thread detailing the math of LiFePo batteries, only that they are lighter, have more energy than SLA batteries, and most are super happy with them. Hopefully some of you will find the following numbers as enlightening as they were to me when I penciled this all out.
Coming from an electrical field (see what I did there) using KWh to determine a batteries capacity is easier and more accurate than going through a table on a battery manufacturer‘s website and trying to poke a needle into that voodoo doll of Ah discharge rates. Let’s face it, most of us are not going to turn things on or off based on discharge rates, we are going to use our devices as we wish and we will want to exploit the advantages the LiFePo batteries’ performance to offset their initial high cost. @Zeusmotorworks use of a single 36V 60 Ah LiFePo battery for his 112# thrust MinnKota Rip Tide troller is a testament to the high usable KWh of a LiFePo battery. https://jetboaters.net/threads/210-fsh-trolling-motor-mount-pics.24573/
I currently have three Deka SLA 12V 90 Ah batteries in series which yields 3.24 KWh of energy, 36 Volts X 90Amp hour rating of the battery, you only use the Ah of 90 because Ah is not additive in a series configuration. However the SLA battery can only be discharged 50% or damage occurs to the battery, so there is only 1.62 KWh of usable energy. Also, the voltage decay in a SLA battery may render the troller in operative even though there is energy left in the battery. I found this out last summer when I heard a double beep from my troller and the only thing it would do is stow itself since the battery voltage was too low. A good design feature for both not leaving too little power to stow the motor, and to prevent damage To the motor.
A single Dakota Lithium 36V LiFePo 63 Ah battery yields 2.26 KWh’s of energy, at a discharge of 95% that leaves 2.147 KWh of usable energy. That’s a 32.5% increase in capacity Over the SLA battery. A battery bank consisting of three Dakota lithium 12V 100 Ah LiFePo batteries will yield 3.6 KWh total, @95% thats 3.42 KWh of usable energy, an increase of 211% in usable energy Over the SLA battery.
Cost:
Other advantages:
Cost:
- 3-Deka SLA 90 Ah batteries=$488, or $301per KWh. ($488/1.62KWh)
- 3-DL 12V 100 Ah batteries= $2399, or $701 per kWh ($2399/ 3.42KWh)
- 1-DL 36V 63 Ah battery= $1699, or $791 per kWh ($1699 / 2.147 KWh)
- 3-Deka SLA 90 Ah batteries=160.5#
- 3-DL 12V 100 Ah batteries= 95.7#, or 59.6% / 64.8# less weight than the SLA bank.
- 1-DL 36V 63 Ah battery=59#, or 63.3% / 101.5# less weight than the SLA bank.
Other advantages:
- Flat voltage curve during discharge
- Slightly smaller overall size
- No sulphuric acid in the storage / head compartment
- Charge in half the time of a SLA battery
- Up 4 times the service life
- LiFePo batteries are not damaged if left in partial state of discharge
- Higher up front cost
- Cannot charge if the battery is less than 32°F. I’ll have to install a heated battery blanket or pad during the shoulder seasons.
- At -35°F the battery will be damaged. So for those rare instances of temperatures in this range the battery (boat) will have to be in my heated shop.
