bleudyno
So I picked up a pair of these cupholder/rodholders to swap out the ones on my swimdeck.
Rod holder
I removed the original ones an noticed that there is a drain tube that connects to the bottom of the cupholder and routes to the little drain hole on the outside right under the cupholder. The issue I am seeing is that since this new cupholder goes down deeper, 1. the tube is too short to connect to the bottom of this cupholder and 2. even if I get a longer tube, the tube will be lower than the drainage hole so if it gets filled with water, it won't drain out due to the fact that the water needs to travel up the tube to the drainage hole. Does anyone who has these installed on the swim deck on ideas to get this installed properly and still have the water able to drain out?
Rod holder
