JDRacing
- Northern Calfornia
- 212X
I've read a post or two from other members commenting on the ballast intake which sits right on a bunk board. My new 2018 212X is like that for the rear tanks. At least I assume that's where the intake is, because otherwise I sure as heck can't find it. The ski locker ballast bag intake is inboard of a bunk and is accessible.
Lake Tahoe, as others have reported, is "extremely particular" (a euphemism) about decontaminating ballast tanks. Talking to one of the officials today by telephone (she was actually really responsive, helpful and friendly), ballast decontamination is required even if the boat is otherwise clean and thoroughly dry. My boat will spend a significant time on Tahoe as well as other lakes in Northern California, all of which are "clean" lakes. Tahoe is the only place in this area that goes to the this length on ballast tanks I believe.
So my question is whether anyone has come up with a (relatively) easy workaround to access the intake for the rear tanks for flushing/decontamination with the boat on the trailer? I was thinking about a couple of inline "T's" in each of the intake lines just downstream of the intake seacock. The stem of the T would have a ballcock valve (or diverter valve) on it which would stay shut until ready to flush, maybe with an easily removable cap. To flush/decontaminate, hook up the hose to the T stem, shut the seacock, open the valve on the T, and the inspector can fill the tank with their 140 degree decontaminating water. I assume the water would go right by the Water Puppy pump, or if there's not enough pressure, run the pump manually. Pump it out when done.
Anybody tried anything like this? Or maybe come up with something better/easier? Be even better if that intake through-hull were located 4" to either side.
Jeff
Jeff
