KXCam22
- Kamloops BC
Face it. The MFI trailer wiring and lights are crap. The first summer I had my boat I spent more hours working on the trailer lights than on the boat. I did two things to fix this. LED lights are a must since the stock waterproof lights I had only succeeded in keeping water in. The seconds was to install a dedicated ground wire down each side of the trailer and connect it to all the lights. This prevent any corrosion induced grounding issues. Here are some wiring diagrams I made. Hope they are helpful. Also note on the ultimate wiring diagram the additional backup flood lights. I added these to help when backing into camping spots in the dark. They also work under water when loading the boat in the dark. Cam
