Welcome to Jetboaters.net!
I think you must have used a bit for the Dewalt Cut-Out tool or a router bit. Both would work well. It sounds like the combination with the spacer made it an easy job.
When I cut my 2 10" subs in my AR, I started with a Jig Saw and it didnt work great. Then I remembered I had a smooth blade for my sawzall that is smooth and used for it for cutting Metal Lav walls. So I tried it and it worked awesome!
Good Luck!
I used an adjustable drill bit to install cup holders. I made several test holes into cardboard to get the exact fit, then I used painters tape, said a long prayer, held my breath and cut the hole.
This one cuts up to 5". Possibly there's one out there that would cut larger holes. View attachment 54391
